1990 Toyota Corolla EINGINE COOLING FAN
EICTOM
Engine Cooling problem
1990 Toyota Corolla 4 cyl Two Wheel Drive Manual
Why does my engine cooling fan stay on all the time?
Oct 21, 2008 at 12:40 AM
MMPRINCE4000
  • 8,548 POSTS
Usually a bad fan switch located in the water housing below the dist.
It is a round white connector, it is designed to run the fan all the time if the fan switch fails (or the connection to it).
While it is possibe the relay is stuck, one test for the cooling fan is to disconnect the fan switch connector, if the fan runs, then the switch is bad.
Oct 21, 2008 at 2:07 AM
