1989 Toyota Corolla Cooling fan is on constantly
197,000 MILES • 4 CYL • FWD • AUTOMATIC
DEVO357
  • 5 POSTS
My cooling fan is on right from start up when cold and does not turn off? I also have a check engine light that popped up and I think its related.
Aug 27, 2010 at 3:40 AM
BLUELIGHTNIN6
  • 16,542 POSTS
coolant temp. sensor most likely fault but will want to retrieve the trouble code(s) stored to make sure
Aug 27, 2010 at 10:52 AM
  • 75,988 POSTS
Jumper Te-1 to E-1 in the check connector to flash the code/s
Aug 27, 2010 at 10:57 AM
MMPRINCE4000
  • 8,548 POSTS
There is a small white round connector under dist. in coolant block, this is fan switch.
Either fan switch is bad or relay is stuck. Check connection to fan switch.
Check fan relay's and "engine main" relay.
Aug 28, 2010 at 1:12 AM
DEVO357
  • 5 POSTS
If I forgot to mention this motor has a carburetor
Here are the code I pulled.
22
31
41
Aug 30, 2010 at 4:23 AM
GEET
  • 34 POSTS
22 is for coolant temperature sensor
31 is for vacuum sensor
41 is for throttle position sensor
Aug 30, 2010 at 4:41 AM
DEVO357
  • 5 POSTS
[quote:06412f7f96="geet"]22 is for coolant temperature sensor
41 is for throttle position sensor[/quote:06412f7f96]
Hmm I dont see how 41 is TPS the motor has a carburetor.
So what do I need to do to get rid of these codes?
Aug 30, 2010 at 7:25 AM
MMPRINCE4000
  • 8,548 POSTS
Disconnect the battery (-) for 5 minutes to erase codes, if they come back on, then further repair is necessary.
Aug 31, 2010 at 1:22 AM
GEET
  • 34 POSTS
[quote:518e7b68cd="mmprince4000"]Disconnect the battery (-) for 5 minutes to erase codes, if they come back on, then further repair is necessary.[/quote:518e7b68cd]
if they come back you have to change the sensor. its weird you have carburetor and it stores code 41.
Aug 31, 2010 at 5:43 AM
MMPRINCE4000
  • 8,548 POSTS
It is also possible the ECM is bad, or that some 89's had FI but used a common ECM with a different PROM.
Sep 1, 2010 at 12:25 AM
