1990 Toyota Corolla Downpipes
80,000 MILES • 4 CYL • FWD • MANUAL
JACKOLSON
  • 67 POSTS
Do you have any info on specs for a downpipe system for a 1.6L 4cl engine?
Engine is 1.6L 4cl DOHC
I'm planning to install new headers, a 4-1 type header
What diameter should I use for the headers pipes?
I'm running it to a downpipe, no muffler, no resonator.
What diameter should I use for the pipe?
It will just be a straight pipe from the header collector end.
Thanks and more power.
Jack
Aug 29, 2009 at 11:55 PM
MMPRINCE4000
  • 8,548 POSTS
I would go no larger than 1.5" on header pipes.
You could also check with TRD (Toyota Racing Development) and see if they offer a factory header.
TRD parts are available from Toyota.
Aug 30, 2009 at 1:24 AM
JACKOLSON
  • 67 POSTS
Thanks man.
Aug 30, 2009 at 4:08 AM
MMPRINCE4000
  • 8,548 POSTS
You are welcome.
Aug 31, 2009 at 1:29 AM
