HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Ignition
Distributor
Replace/Remove
1990 Toyota Corolla distributor
NADIN
MEMBER
1990 TOYOTA COROLLA
4 CYL
FWD
MANUAL
100,000 MILES
How to replace distributor oil seal.
Saturday, February 23rd, 2008 AT 3:01 AM
MECHANIC
Make a mark at the distributor base and engine block-remove the distributor cap mark the position of the rotor tip and the housing. Then pull it out-replace the seal. Going back in make sure you match all the marks if not the timing will be off.
SPONSORED LINKS
Saturday, February 23rd, 2008 AT 3:12 AM
Please
login
or
register
to post a reply.
Related Ignition Distributor Replace/Remove Content
1993 Toyota Corolla Distributor
My Car Recently Quit On Me. Toyota Dealership Is Replacing The Coil Pack, Which They Said Would Get It Running Again. During Their...
Asked by
ashliman
1 ANSWER
1993
TOYOTA COROLLA
1990 Toyota Corolla Distributor
1990 Toyota Corolla Automatic 84000 Miles When My Car Broke Down, The Mechanic Told Me I Needed A New Distributor Cap/rotor. I Had...
Asked by
nwhelton
1990
TOYOTA COROLLA
1990 Toyota Corolla
Hi I Have A 90 Corolla 2 Years Ago It Quit Running I Found No Spark So I Went To The Junk Yard Got A New Igniter And It Ran. I Just Stopped...
Asked by
bestdada
1990
TOYOTA COROLLA
1991 Toyota Corolla Ignotor & Pick Up Coil Test|
Electrical Problem 1991 Toyota Corolla 4 Cyl Front Wheel Drive Automatic How Do You Test And Ignitor & Pick Up Coil To Identify A...
Asked by
pito soto
1 ANSWER
1991
TOYOTA COROLLA
1995 Toyota Corolla Componet Location
Electrical Problem 1995 Toyota Corolla 4 Cyl Front Wheel Drive Automatic It Was Recommende By Rasmataz, One Of Your Mechanics To...
Asked by
alexreba
1995
TOYOTA COROLLA
VIEW MORE
SPONSORED LINKS
What to Do When a Check Engine Light?
Spark Plug Replacement Ford F150 5.4L
Check Engine Light Safe to Drive?
Online car repair manuals
