ON THE DRIVER SIDE OF MY CAR WHERE THE DRIVE AXLE GOES INTO THE DIFFERENTIAL THERE IS A HUB BOLTED TO THE SIDE OF IT. THE DRIVE AXLE PASSES TRU THIS HUB. MY PROBLEM IS THERE IS A BEARING INSDE THE HUB THAT HAS AN OUTER RACE PRESSED IN THE HUB AND THE INNER RACE AND BEARING CAGE SLIDES OVER THE SHAFT THAT MY DRIVE AXLE SPLINES SLIDE INTO IS BAD.DOSE ANYONE KNOW WHAT THIS BEARING IS CALLED? ALSO THE DRIVE (I WILL CALL IT) INSIDE THE DIFFERENTIAL IS LOOSE, MOVING UP AND DOWN A LITTLE IS PART OF TEH BEARINGS JOB TO STABILIZE THE DRIVE? PLEASE HELP.
Apr 6, 2009 at 5:05 AM
