1990 Toyota Corolla Brakes
1990 TOYOTA COROLLA
SWINDELL46
1990 Toyota Corolla Front Wheel Drive Manual
The driver side caliper won't engage the rotor. When brake is engaged the piston comes out slightly then goes back in. Replaced the caliper, does the same thing. Master cylinder? Thanks for any help.
Oct 1, 2008 at 12:17 PM
MMPRINCE4000
  • 8,548 POSTS
Bleed that caliper to make sure there is no air. Check the hose and line for restrictions, otherwise it could be the MC.
Oct 2, 2008 at 12:18 AM
