1990 Toyota Corolla air flow meter
ISLANDDAVE
  • 1990 TOYOTA COROLLA
Engine Performance problem
1990 Toyota Corolla 4 cyl Two Wheel Drive Automatic
where is the air flow meter located, and what does it look like? Its a 90 corolla station wogon with 4AFE engine
Friday, October 10th, 2008 AT 11:18 PM
MMPRINCE4000
  • 8,548 POSTS
If you are talking about a MAF (mass Air Flow) sensor, they use a MAP (Manifold Absolute Pressure) on this model.
It is on the firewall behind the intake manifold and has a vacuum line attached to it and the intake manifold.
The IAC (idle air control) is on the throttle body assy.
Saturday, October 11th, 2008 AT 6:16 AM
