1990 Toyota Corolla
280,000 MILES • 4 CYL • FWD • AUTOMATIC
BESTDADA
Hi i have a 90 corolla 2 years ago it quit running i found no spark so i went to the junk yard got a new igniter and it ran. I just stopped again 2 weeks ago i got another dist from a junk yard and no good so i bough a reman dist no good so i bought a new one still no good i have inspected for power at the ecm and all fuses the are good i inspected the pick up coils and the resistance is in spec i have power in to the dist from the 2 wire connector to the coil and ingniter. I also checked for my engine ground and it is good. The relays under the hood MFI i swapped and still nothing. i got a junk yard ECM and nothing. i have fuel i opened the fuel line and cranked veh and got fuel. No spark please help
May 15, 2010 at 8:11 AM
  • 75,988 POSTS
Check the Ne, G, Igt, and Igf wiring back to the computer.
If the computer don't get the Ne and G signals it will not give an Igt signal tell the ignitor to fire the coil and no Igf meaning no combustion occurred.
May 15, 2010 at 9:11 AM
BESTDADA
I have checked at the ecm with a ohm meter on beep test when i crank the veh i hear a a tone every time a single is sent to the ecm. from wire G- to G1 and G- to NE that is why i am so troubled. I have a dealer repair manual i feel like i am missing a sensor or relay but am so upside down i feel lost
thank for trying
May 15, 2010 at 10:08 AM
