1990 Toyota Corolla
BOOK
Transmission problem
1990 Toyota Corolla 4 cyl Front Wheel Drive Automatic
I had my aunts boyfriend put on my cv axle and now my transmission fluid is leaking and when i back my car up it is making a noise whats wrong with it.
Jun 10, 2010 at 11:53 PM
  • 31,937 POSTS
These autos have a separate oil supply for the diff there is a plug on the back of the diff housing, i will take 1.5 lites Dextron 11 you will have to check that the drive shaft oil seals are not leaking.
Mark (mhpautos)
Jun 11, 2010 at 12:13 AM
MMPRINCE4000
  • 8,548 POSTS
As Mark said, DO NOT let the differential run out of fluid, or it will sieze.
The axle seals are leaking, use Toyota seals, they are much better than aftermarket seals.
Jun 11, 2010 at 12:44 AM
