1989 Toyota Corolla Very slow acceleration
235,000 MILES • 4 CYL • FWD • MANUAL
JESSICOOL
My car is accelerating incredibly slow and doesnt like going past 25mph. it makes a weird noise like air sucking or blowing out. I have been told by a friend that it is not getting enough fuel or the fuel to air ratio is off. How would I go about fixing it and could that be the cause of the slow accelleration? I have recently changed the air filter and the spark plugs.
Mar 2, 2010 at 4:39 PM
  • 75,988 POSTS
Hesitation,chugging,lack of acceleration,bogging,etc.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Mar 2, 2010 at 4:43 PM
