1989 Toyota Corolla Speedometer doesn't work
1989 TOYOTA COROLLA
LOU ANN
1989 Toyota Corolla 194559 miles
The speedometer just all of a sudden stopped working. If I unhook the battery cable and rehook it up, will that work?
Dec 4, 2008 at 9:35 AM
MMPRINCE4000
  • CERTIFIED EXPERT
  • 8,548 POSTS
No, it is cable driven. Remove the lower cable (connects to trans) and see if it is broke, it is usually the one that goes first.
You may need to remove the air cleaner and TB hose for better access. Replacement lower cables are available from Toyota and are about $60 bucks or so.
Dec 4, 2008 at 9:38 AM
