1989 Toyota Corolla Removing Axle
LADYT98661
1989 Toyota Corolla 4 cyl Two Wheel Drive Manual
My son is putting a new clutch in my Corolla GTS. He's having trouble getting the axle out. Could you please tell us if there's a trick to getting it out.
Thank You
Feb 5, 2010 at 9:07 PM
MMPRINCE4000
  • 8,548 POSTS
Nope, they "pop" out. The best tool to use is a slide hammer with an CV axle attachment.
You can get a long heavy screwdriver and put on slot on tripod side, (from opposite side) use hammer and whack it a few times.
Some cars have axles that are bolted to trans, but most use a "C" clip at end of axle that compresses as it is going in then expands into slot in trans.
They can sometimes be a pain to get out.
Go to autoparts store and look at replacement axle, and you will see the small "C" clip that holds axle in.
Feb 5, 2010 at 11:47 PM
