HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Engine Cooling
Radiator
1989 Toyota Corolla radiator
JAIJO38
MEMBER
1989 TOYOTA COROLLA
4 CYL
FWD
MANUAL
125,000 MILES
Where is the "bleeder" of radiator located?
Tuesday, October 12th, 2010 AT 5:13 PM
BLUELIGHTNIN6
MECHANIC
If radiator has a bleed valve than it will be on the top area of the radiator either on the driver or passenger side corner of radiator. Otherwise just remove radiator cap and start engine, let run to operating temperature to bleed system.
SPONSORED LINKS
Tuesday, October 12th, 2010 AT 6:26 PM
Please
login
or
register
to post a reply.
Related Radiator Content
Radiator
How Do I Flush The Radiator On A 1995 Corolla
Asked by
ThunderDan
1 ANSWER
1995
TOYOTA COROLLA
GUIDE
Radiator
Radiators consist of a few basic parts, two tanks and the core. The radiator "tanks" located on the sides or top and bottom are used to attach upper and lower coolant hoses...
1991 Toyota Corolla Radiator Cleaning
Engine Cooling Problem 1991 Toyota Corolla Front Wheel Drive Automatic 32030 Miles How Do We Clean The Radiator? The Holes Are Clogged...
Asked by
edlover
1 ANSWER
1991
TOYOTA COROLLA
2008 Toyota Corolla
What Is The Procedure To Add Coolant To A New Radiator For A 2008 Toyota Corolla
Asked by
muggers05
1 ANSWER
2008
TOYOTA COROLLA
Type Of Coolant To Use
1.8, At, 172k. It's Time To Replace The Coolant And I Want To Do It Myself. I Get Conflicting Opinions About What Type Of Coolant To...
Asked by
jcantergiani
2004
TOYOTA COROLLA
Leaking Antifreeze
My Car Ran Out Of Antifreeze. I Don't Know When. We Put Pre-diluted Antifreeze Back In The Car, But Now It Won't Start. I Have...
Asked by
mhafweet
1990
TOYOTA COROLLA
VIEW MORE
SPONSORED LINKS
Engine Oil Inside Radiator
Radiator Replacement Kia Sportage
Online car repair manuals
