1989 Toyota Corolla Not enough compression in cylinder No1
ERVINW
  • 5 POSTS
Engine Mechanical problem
1989 Toyota Corolla 4 cyl Front Wheel Drive Manual
We checked the rings that was ok, then we changed grinded the valves, same problem.
We then changed the engine Head, still same problem
May 31, 2010 at 8:49 AM
  • 31,937 POSTS
Hi there,
do a wet compression test, add a table spoon or so of oil to this cylinder and do a comp teas, if the pressure comes up it will be a ring problem, if not valves or gasket problem, ensure that you have correct valve clearance as well.
mark (mhpautos)
May 31, 2010 at 10:18 AM
ERVINW
  • 5 POSTS
Hi Pro
We tested the cylinder wet and compression was the same. the engine has overhead cam so valve clearance is good, the head joint was replaced...what else should i check.
Thank you
Jun 18, 2010 at 9:58 PM
  • 31,937 POSTS
Do a leak down test, this will show exactly where the leak is, you do need some special equipment to do this, but if the comp is still low, it will be a vale problem head gasket or a hole in a piston, a leak down test will prove exactly where the problem is.
mark (mhpautos)
Jun 18, 2010 at 11:09 PM
