1989 Toyota Corolla leaking
14,000 MILES • 4 CYL • FWD • MANUAL
OMIEMOM54
Had the air worked on multiple times. It leaks under the passenger dash into the floorboard a lot. When they stop it from leaking the air is not cold at all . Help
Sep 1, 2009 at 5:30 AM
MMPRINCE4000
  • 8,548 POSTS
Take it back to the mechanic who last worked on it and demand it be repaired at their expense.
They should also have converted it to R134A, although R12 is still available, it is VERY expensive.
https://www.2carpros.com/how_does_it_work/air_conditioner.htm
Sep 1, 2009 at 11:12 PM
