1989 Toyota Corolla installing drive axles
KENNYRDNEK
Drive Train Axles Bearings problem
1989 Toyota Corolla 4 cyl Front Wheel Drive 133824 miles
installed new axles a month ago and appears driver side has come out how do u install and make sure its lock in
Dec 8, 2008 at 8:47 AM
MMPRINCE4000
  • 8,548 POSTS
There is a small "C" clip that retains the tripod to the trans.
It may have come off or is deformed. Remove axle and check "C" clip.
Once you snap the axle in it should not move out, if it does, it is not in correctly.
Dec 9, 2008 at 1:00 AM
