1989 Toyota Corolla CV joint
JLOVE229
Transmission problem
1989 Toyota Corolla Engine Size unknown Wheel Drive Type unknown Automatic 189000 miles
I have a toyota corolla. Year 1989. I need to know the name of the part that turns the wheel in the transmission and it is connected to the cv joint.
Dec 27, 2007 at 4:22 AM
BMRFIXIT
  • 19,053 POSTS
[quote:4e3e8108d6="JLOVE229"]Transmission problem
I have a toyota corolla. Year 1989. I need to know the name of the part that turns the wheel in the transmission and it is connected to the cv joint.[/quote:4e3e8108d6]
you have tranny cv axel bearing hub then brake rotor and tire
Dec 31, 2007 at 1:19 PM
CAB10048
Most times it is cheaper and easier to replace the half shaft.
Most parts stores have this or even check the junk yards for a cheaper fix.
Buy a Chilton Book and read it.
Jan 4, 2008 at 11:31 PM
