1989 Toyota Corolla 4 cyl Front Wheel Drive Manual
Just had a compresion test done on the 89 corolla.
Has good compresion and it was mentioned that I would need to make an adjustment or a carb-re-build.
Just replaced the plugs the other day and they smelled badly of gas and were pretty dark. Now the new ones are the same color after only a few days. Car is always bogging down as if it's flooding out or something?
So is there a way I can try adjusting the carberator to see if that helps any or what do u think I should do?
Thanks for any help.
SPONSORED LINKS
Thursday, June 12th, 2008 AT 10:15 PM
