I Just did and engine swap the engines were identical with the exception of one component located on the head it is on the front of the motor I do not think it does anything but not sure. But anyhow the car will not start it is like the timing is off is will hit but when it does the whole engine jumps I am woundering did I miss something I have done tons of engine swaps but never this problem the old engine ran but had a rod out of it the new engine also ran when pulled (it is suppose to be a japan import engine) thank you for the help
Jan 24, 2007 at 2:01 AM
