1989 Toyota camry lights
THEWIZARD1026
Electrical problem
1989 Toyota camry 6 cyl Automatic 158700 miles
how do i change license plate lights /sometimes i have trouble starting the car you can hear fuel pump working but car wont start sometimes it takes 20 or 30 trys
Oct 25, 2008 at 3:49 AM
MMPRINCE4000
  • 8,548 POSTS
Generally the plate lights are changed from outside, but look inside trunk and see if there is access to it.
Have the fuel pressure checked with a mechanical gauge, if low, it may indicate a weak/bad pump.
Also remove fuel pressue regulator vacuum line for gas, if present, then the FPR has a ruptured diaphram and would need to be replaced. This could cause starting problems, since excessive gas would be pulled into intake and flood engine.
Oct 26, 2008 at 1:02 AM
