1988 Toyota Corolla WATER PUMP REPLACEMENT
HULA1123
  • 1988 TOYOTA COROLLA
1988 Toyota Corolla Manual
Hello I need to replace my water pump on my 1988 toyota corolla fx but I cant seem to get to the part can you help please
Sunday, December 14th, 2008 AT 4:39 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,363 POSTS
Hey Hula1123,
Drain cooling system. Loosen alternator pivot bolt, swing unit toward engine and remove drive belt. On A/C equipped models, remove fan shroud. Remove fluid coupling with fan, water pump pulley and drive belt.
Remove water outlet housing, by-pass pipe, water inlet housing, thermostat, timing belt upper cover and oil dipstick tube. Disconnect heater outlet hose from pipe and remove heater outlet pipe mounting bolt. Remove water pump.
To install water pump, mount heater outlet pipe, with new gasket, to pump. Place new "O" ring gasket on clean block surface and mount pump. Install new "O" ring onto dipstick tube and mount to block.
To complete installation, reverse removal procedure. Adjust tension of drive belts, fill coolant system, start engine and check for leaks.
Please let us know happens so it will help others.
Best, Ken
Monday, July 27th, 2020 AT 4:46 PM
