First take to any autoparts store and have the charging system tested. If you can jump start it then go to autoparts store, if you cannot jump it, then the problem is starter or ign. Switch, or bad electrical connection.
Battery may have 12V but no amps (or very little).
Starter is located in rear (firewall side) where engine and transmission mate. They can be difficult to see, because of intake manifold.
SPONSORED LINKS
Thursday, April 9th, 2009 AT 9:27 AM
