1988 Toyota Corolla SR5-Check engine light
CHANMAN828
  • 1988 TOYOTA COROLLA
  • 4 CYL
  • 11,300 MILES
My check engine light randomly comes on after about 20 minutes or so of driving. It is not on when the car gets turned on but turns on a bit later. When it comes on, I can feel a bit of a jolt from the engine. I read some of the other forums and read that it may be a loose spark plug wire? So I just replaced the entire distributor, rotor, wires, plugs, spark plugs and timing belt all together and it still popped up a check engine light soon after. What could this be, maybe an oxygen sensor? Or do I have to just get the code to reset the check engine light?
Saturday, July 11th, 2009 AT 2:49 PM
  • 31,937 POSTS
Hi there,
You will need to get the set fault code information, there is still a problem there and the code will help identify where it is, start here.
Mark (mhpautos)
Saturday, July 11th, 2009 AT 9:06 PM
