1988 Toyota Corolla Ignition Cylinder Replacement
1988 TOYOTA COROLLA
218,000 MILES • 4 CYL • FWD • AUTOMATIC
BDBICKFORD
I removed the ignition locl cylinder in order to replace the ignition switch, and now I can't get it back in. It will sllide in until I can see about 1/2 of the pin through the hole in the housing, but go no further. I think it has something to do with the part that connects the ignition lock cylinder to the ignition switch, but I don't know what the part is called, nor can I find any reference to it anywhere. Does anyone know what this part is called?
Jul 21, 2009 at 10:16 AM
BLUELIGHTNIN6
  • 16,542 POSTS
see if this helps..
Position the ignition switch so that the recess and the bracket tab are properly aligned. Install the retaining screw.
Make sure that both the lock cylinder and the column lock are in the ACC position. Slide the cylinder into the lock housing until the stop tab engages the hole in the lock.
Make certain the stop tab is firmly seated in the slot. Turn the key to each switch position, checking for smoothness of motions and a positive feel. Remove and insert the key a few times, each time turning the key to each switch position.
Connect the switch if it was removed from the lock assembly.
Connect the wiring harness and check the assembly for proper operation.
Reinstall or connect any wiring bands, clips or retainers which were loosened. It is important that the wiring be correctly contained and out of the way of any moving parts.
Reinstall the combination switch and the steering wheel if they were removed.
Install the steering column trim and the upper and lower column covers.
Connect the negative battery cable.
Jul 21, 2009 at 1:54 PM
