1988 Toyota Corolla CRUISE CONTROL
230,000 MILES • 4 CYL • FWD • MANUAL
YNOTBOB2008
I just had the engine completely rebuilt and all is well except the cruise control cuts out after a few miles, then blinks, then the light turns off. I can turn it back on and it will do the same thing. The entire unit was replaced a few years back so I feel this is due to something in the reassembly of the rebuild rather than the unit. The check engine light has not come on so I haven't checked for trouble codes yet. Thanks for your help.
Feb 1, 2008 at 8:47 AM
2CARPRO JACK
  • 11,533 POSTS
Be sure it has good vacuum to the cruise unit. That all grounds are hooked up. Does it hold a steady speed when it does work?
Feb 2, 2008 at 12:42 AM
YNOTBOB2008
Thanks Jack,
I'll check the vacuum (didn't know it had one) and ground. Yes, it holds a steady speed when it works. The last two trips out (today and yesterday) has been fine....10 miles each way with cruise on working properly. Maybe the engine needed a few more miles to break in (it literally was finished last week).
Thanks,
Bob
Feb 2, 2008 at 3:33 PM
2CARPRO JACK
  • 11,533 POSTS
Get back if it quits again
Feb 3, 2008 at 12:27 AM
