1987 Toyota Corolla Transmission change
145,000 MILES • 4 CYL • FWD • AUTOMATIC
GPSJR10
I have a Nova that has the A131L 3 speed transmission in it and I would like to change it to a 4 speed trans, Will a different trans fit the 1.6L engine?
Aug 27, 2008 at 2:38 AM
MMPRINCE4000
  • 8,548 POSTS
This is a difficult question. It depends on the engine (4ALC, 4AGE etc.) and if it was offered in 1987.
Later years (89- up) offered the A420, but in any case you would need new mounts (if the car was offered with the 4 speed), otherwise you would have to fabricate new mount holes in the lower frame.
A factory manual would tell you if the 4 speed was offered.
Also the A131L shifting was controlled by a kick-down cable, while (I believe) tha A420 was controlled by vacuum.
You could also ask a junk yard if the 4 speed was offered.
While anything is possible you may wind spending a lot of money to get the extra gear.
Aug 27, 2008 at 9:57 PM
