If you had a bad valve it should have shown up on the compression test.
If you have good compression and spark, the only thing missing is fuel.
I would try a can of SeaFoam in the tank, see if it helps clean the varnish in the carb.
If a 4ALC engine, valve clearence is relitively easy to set.
SPONSORED LINKS
Sunday, September 27th, 2009 AT 7:15 AM
