1987 Toyota Corolla REPLACING CAMSHAFTS
1987 TOYOTA COROLLA
110,000 MILES • 4 CYL • 2WD • AUTOMATIC
LUCKYJS
  • 12 POSTS
(I hope my donation is attached to this question, the Paypal return-to-index didn't indicate that there was a connection)
I am replacing the head gasket on a 1987 Toyota Corolla SR-5, A-F engine.
I removed the camshafts & sprocket and continued with the head gasket replacement. Now I am attempting to put it back together but have run into a problem - or at least a question:
Which direction is the "sprocket timing hole" supposed to face?
The cams and sprocket were removed intact, but when they are meshed with the alignment marks together, the sprocket timing hole is off 90 degrees from the top, pointing to the rear of the car. I don't know that it wasn't this way to start with, but the instruction in the Haynes manual has me baffled. "align the camshaft sprocket timing hole with the center mark on the cylinder head" (illustration shows the hole at the top of the sprocket, not 90 degrees to the right.
This manual does cover several engines (ours is the A-F) but there is no indication that this is different between them.
Can you help?
Feb 27, 2008 at 8:40 AM
Is this a 1.5L or 1.6L engine? also see below
https://images.2carpros.com/forum/automotive_pictures/12900_corrolla_timing_alignment_1.jpg
Feb 27, 2008 at 9:41 AM
2CARPRO JACK
  • 11,533 POSTS
They almost always point up.It is a good idea to make your own visible marks or take a digital pic before disassembly
Feb 27, 2008 at 10:03 AM
LUCKYJS
  • 12 POSTS
your illustration looks like a chevy V8 :)
The car is a 1987 Toyota Corolla SR-5 with the 4A-F engine (as opposed to 4A-GC, 4A-C, 4A-GE) and
1.6 liter Toyota standard engine.
I can take a picture of this dilemma in the morning if that will help. I've been repairing and rebuilding cars my entire life but have never been baffled like this.
The 2 gears on the cam have the marks on them toward the bell housing side, and they are meshed according to the manual, with the marks facing each other. All looks fine. Except - on the Timing belt sprocket the timing hole lies horizontally - flush with the top of the head. this part has never been removed from the car.
If I turn the timing belt sprocket up, so that the timing hole is at the top, then the meshed marks on the inside of the cam would be straight up, not horizontal as it is now. I would have to also rotate the intake cam so that it's mark would be up also.
Which way is correct? What am I missing here?
Am I making sense?
Thanks!
Lucky
Feb 27, 2008 at 2:35 PM
Jack-This engine is similar to the Camry's 3S-FE 4cyl. Let me go and hunt this 4A-F engine-I'll be back-
Hang in there -I'll get you squared away-it does look like a Chevy timing chain arrangement-
Feb 27, 2008 at 3:12 PM
LUCKYJS
  • 12 POSTS
Great!
I'll be here, holding my breath!
Lucky
Feb 27, 2008 at 3:19 PM
Your set up does it look like this-also do you have a seperate cam sprocket for the exhaust and intake valves.
Feb 27, 2008 at 3:38 PM
LUCKYJS
  • 12 POSTS
no image included, the link just brought up an ad from Edmunds.
Yes, they have separate sprockets. They have the knock pin alignment holes and the timing pully goes on the front, outside the valve cover.
Lucky
Feb 27, 2008 at 3:44 PM
Does yours looks like this?
https://images.2carpros.com/forum/automotive_pictures/12900_camshafts_1.jpg
Feb 27, 2008 at 3:52 PM
LUCKYJS
  • 12 POSTS
No, that looks like the 4A-GE engine.
on mine, the timing belt only drives off of the exhaust cam.
Luckyt
Feb 27, 2008 at 3:54 PM
What about this
https://images.2carpros.com/forum/automotive_pictures/12900_3SFE_1.jpg
Feb 27, 2008 at 4:02 PM
Camshaft sprockets for the exhaust/intake are they messed together
Feb 27, 2008 at 4:07 PM
LUCKYJS
  • 12 POSTS
Yes, that's more like it.
The cam installation marks line up on the inside when the exhaust camshaft knock pin is positioned about 9:00, and the intake camshaft knock pin is positioned about 5:00.(illustration in Haynes manual)
Lucky
Feb 27, 2008 at 4:13 PM
On Toyota 1.6L DOHC 4AF and 4A FE engines in Corolla and Celica models, timing the camshafts also can be confusing because the cam gears have two sets of timing marks. Each set of marks has a particular purpose. One set is used to time the intake with the exhaust camshaft when they are mounted in the cylinder head, and the other set indicates the TDC position for both camshafts.
I've done this before with this engine back in the early 90's just not kicking in. Just hang in there, am giving it all I got
Feb 27, 2008 at 4:29 PM
LUCKYJS
  • 12 POSTS
[quote:f9818b666f="rasmataz"]Camshaft sprockets for the exhaust/intake are they messed together[/quote:f9818b666f] Yes, they mesh perfectly. The only problem is that when they do, the mark on the timing belt sprocket is 90 degrees from the top, point to the rear of the car.
Lucky
Feb 28, 2008 at 3:28 AM
The knock pin for the intake camshaft-where is it located, also the exhaust cam knock pin-
Feb 28, 2008 at 9:50 AM
MMPRINCE4000
  • 8,548 POSTS
The 4AFE has a removal and installation position. Once installed you rotate the cams back to the timing position using a cresent wrench on one of the square spots on the camshafts.
In other words, you put the engine to TDC #1, then you have to rotate the cams (timing belt removed) to install the service bolt in the intake cam. You take the caps/cams out. Reinstall, take the service bolt out and then rotate back to timing (service bolt hole would be at 9:00) and 2 timing marks on front of cams would be pointing at each other
Feb 28, 2008 at 10:55 PM
LUCKYJS
  • 12 POSTS
[quote:de263301c7="rasmataz"]Go to this link read thru it and get back to me in PM
www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/16/9f/ca/0900823d80169fca.jsp - 107k[/quote:de263301c7] Read, printed, re-read, re-read, re-read - it's getting clearer - but I'm not quite there yet either.
Interesting info from mmprince4000 - I still feel like i"m stuck in the twilight Zone - but it looks like I may be about to find my way out.
Feb 29, 2008 at 1:43 AM
LUCKYJS
  • 12 POSTS
[quote:4ae1f19230="mmprince4000"]The 4AFE has a removal and installation position. Once installed you rotate the cams back to the timing position using a cresent wrench on one of the square spots on the camshafts.
In other words, you put the engine to TDC #1, then you have to rotate the cams (timing belt removed) to install the service bolt in the intake cam. You take the caps/cams out. Reinstall, take the service bolt out and then rotate back to timing (service bolt hole would be at 9:00) and 2 timing marks on front of cams would be pointing at each other[/quote:4ae1f19230]could you be more specific about this "service bolt"? The specs for the bolt are shown in the Auto Zone document - but i'm not clear on it's purpose. Aren't we bolting together two items (gear and subgear) that are already attached via a lock washer?
Lucky
Feb 29, 2008 at 2:08 AM
MMPRINCE4000
  • 8,548 POSTS
[quote:5b3002dd2f="luckyjs"][quote:5b3002dd2f="mmprince4000"]The 4AFE has a removal and installation position. Once installed you rotate the cams back to the timing position using a cresent wrench on one of the square spots on the camshafts.
In other words, you put the engine to TDC #1, then you have to rotate the cams (timing belt removed) to install the service bolt in the intake cam. You take the caps/cams out. Reinstall, take the service bolt out and then rotate back to timing (service bolt hole would be at 9:00) and 2 timing marks on front of cams would be pointing at each other[/quote:5b3002dd2f]could you be more specific about this "service bolt"? The specs for the bolt are shown in the Auto Zone document - but i'm not clear on it's purpose. Aren't we bolting together two items (gear and subgear) that are already attached via a lock washer?
Lucky[/quote:5b3002dd2f]
Yes, but for me it gives me a good reference point and you would need it to remove the subgear. The service bolt is an M6 x 1.0 bolt about 15mm long. It cannot be put in at the timing position because the head casting is in the way, so you rotate the cams to install it.
If you rotate the exhaust camshaft (cresent wrench on square camshaft boss) so that the pulley mark is at 12:00, the service bolt hole is at 9:00 and the OUTSIDE (timing belt side) marks on the camshafts are pointing at each other, you are in good shape and can install the timing belt, the inside camshaft marks are installation marks not timing marks.
otherwise:
You have to remove the intake camshaft.
Position the exhaust camshaft so that the knock pin is just above 9:00 Do this by rotating the camshaft with a cresent wrench on one of the square castings on the camshaft. There is a prior step, but the exhaust camshaft is already installed.
Mesh the intake and exhaust by matching the installing marks (dots on the inside of each camshaft).
Roll the intake cam into position, install bearing caps. I tighten from center out in 1/4 turn increments.
Remove service bolt and then rotate the camshafts into timing position with a cresent wrench on the square boss of the exhaust camshaft (Haynes manual does not specifically say this that I can find)
Timing position would be the service bolt hole at 9:00, the timing marks on the FRONT (not inside) of the camshafts would be pointing at each other, and the hole in the timing belt pulley would be at 12:00. Then you can install the timing belt, just make sure the lower belt cog timing mark is pointing at timing mark on the oil pump.
This make sense?
Feb 29, 2008 at 3:02 AM
LUCKYJS
  • 12 POSTS
Thanks!
I believe I've got it now. I can't get to the car until Saturday, but will print and take your message with me for reference.
Lucky
Feb 29, 2008 at 12:44 PM
LUCKYJS
  • 12 POSTS
THANK YOU for all your expert help.
Learning about that second set of marks was all it took (as in: it was right in the first place, but I just couldn't SEE it!)
I apologize for the delay in posting this. I am a Pancreatic Cancer patient at UCLA Medical Center and sometimes get a bit knocked down for a few days after chemo treatments.
The car is completed, my sister-in-law is thrilled and says it hasn't run this well in a very long time.
THANKS AGAIN!
Lucky
Mar 9, 2008 at 7:41 AM
