1987 Toyota Corolla No fuel when the engine is hot
110,000 MILES • 4 CYL • FWD • MANUAL
BEAR462
Hi. My 87 corolla (carb 1587cc) will run perfectly from a cold start but then after stopping will not restart when hot. The mechanical fuel pump will not pump fuel to the carb. (I've pulled of the hose and checked). I have replaced the fuel pump and the filter but the problem persists. After leaving the car for about an hour it begins to pump fuel again and eventually starts and runs perfectly.
Sep 14, 2008 at 9:23 PM
  • 31,937 POSTS
Hi there,
You may have excessive vacuum building up in the fuel tank, have the carbon canister replaced and see if that improves the problem, one way to do a quick test, take off the fuel cap when it wont start, if it sucks air (vacuum in tank) i would be looking at the carbon canister first.
Mark (mhpautos)
Sep 14, 2008 at 9:30 PM
  • 75,988 POSTS
If its not vapor lock then there's a problem with the carb.
Sep 14, 2008 at 9:33 PM
