1987 Toyota Corolla Electronics Problem
1987 TOYOTA COROLLA
200,000 MILES • 4 CYL • FWD • MANUAL
JOLAN
The radiator fan on my brother's car doesn't seem to work at all. It works fine when directly connected to the battery, but even when I try removing the plug from the thermostat switch (to test if it works permanently), it doesn't.
I'm not sure if this could be adding to the problem, but say if you were to pull out the battery & place another one whilst the engine is running on idle, the car stalls (where as on a normal car, the engine wouldn't cut out).
May 26, 2009 at 5:52 PM
*** Could be the engine temperature gauge switch or coolant temperature sensor/fan relay
The old says if it continues to run the alty is good ???????????????? for me
May 26, 2009 at 6:15 PM
