Check timing belt for cracks or missing teeth, change belt at 60K.
Also measure fuel pressure with mechanical gauge.
Remove plug, attach wire, pull FP fuse and ground plug to cam cover bolt, crank engine, spark sjould be blue snapping, anything else is considered no spark.
This could be a low fuel pressure problem, caused by bad pump or clogged filter.
Also could be an ignitor going south, ignitor is in dist.
Another possibility is weak coil.
Check with autoparts stores, on many Toyota's it is actually cheaper to buy a remufactured dist. With ignitor rather than the ignitor itself.
Thursday, October 29th, 2009 AT 10:08 AM
