1986 Toyota Corolla Transmission rebuild
HACHI
  • 7 POSTS
Transmission problem
1986 Toyota Corolla 4 cyl Two Wheel Drive Manual 1xxxxx miles
I was just wondering, what is included in a transmission rebuild service?
Jul 31, 2008 at 8:45 AM
  • 31,937 POSTS
Hi there,
With a manual transmission, you should have all the bearings, replaced and the scyncros as well if they are worn, some general mechanics wont replace syncros if they measure up OK, the shifter hubs are normally quite OK to re use, and all seals and any gaskets will be replaced. It is also a good idea to have the clutch inspected as well as if it is worn it is a good time to replace this as well while the box is out.
Mark (mhpautos)
Jul 31, 2008 at 10:43 AM
