1986 Toyota Corolla DISTIBUTOR
1986 TOYOTA COROLLA
WAZZA83
1986 Toyota Corolla 4 cyl Front Wheel Drive Manual
WONDERING HOW TO CHANGE THE O RING FOR THR DISTIBUTOR
Sep 22, 2008 at 2:27 AM
MMPRINCE4000
  • CERTIFIED EXPERT
  • 8,548 POSTS
Set engine to TDC #1, rotor will be pointing to #1 wire on dist.
Mark the orientation of rotor, pull off cap. Loosen dist. hold down bolt, remove bolts (there may be two), pull dist. out, remove old O ring, install new one.
Most Toyota distributors don't have a gear on the dist. so they can be put in only one of two ways, correctly, or 180 degrees out.
Sep 22, 2008 at 7:09 AM
