1985 Toyota Corolla Starter wont start
MGUBASIC
Engine Mechanical problem
1985 Toyota Corolla 4 cyl Front Wheel Drive Automatic
My car dont start but its making clicking sound when try to start I ried to change battery still same problem.Just before that I used screw driver to start it at the stater it was running but I turned it off that was for good what must I do pls help?
Jun 13, 2010 at 10:02 PM
  • 75,988 POSTS
Won't crank at all/nothing -check the starter relay, transmission range switch and ignition switch
Jun 13, 2010 at 10:50 PM
MGUBASIC
Thank you Rasmataz,I just want to find out if there is no oil transimsion what does the car do can it start or not.replying to this will help a lot.
Jun 13, 2010 at 11:24 PM
  • 75,988 POSTS
An engine will start with or without a transmission
Jun 14, 2010 at 12:09 AM
