1985 Toyota Corolla headligth
TIENVY
Electrical problem
1985 Toyota Corolla 4 cyl Two Wheel Drive Automatic
while i am driving at night, sometime the headlight go brighter and back to normal or heater fan go faster and back to normal. i recently changed the battery because water inside one hole was dried even it only over a year old battery. Now with the new battery i still have the same problem. Could you tell me what wrong with it. Really appreciated.
Jul 6, 2009 at 8:57 PM
  • 31,937 POSTS
HI there,
This will be faulty voltage regulator with in the alternator, the system charge rate is to high causing these problems and this will also cause the battery to boil causing further problems, have the alternator o?hauled.
Mark (mhpautos)
Jul 6, 2009 at 11:31 PM
