1985 Toyota Corolla hazard warning switch
30,000 MILES • 4 CYL • FWD • MANUAL
DADBEAR
hi the problem i have is that when switching on the hazard warning light--neither the hazard lights or indicators/flashers work. when the hazard light switch is off the indicators/flashers work as normal. is the problem the switch or the relay? i have swopped the indicator/flashe relay unit between cars and it works fine in bothe cars so its not the flasher relay.?????
Dec 25, 2009 at 9:01 PM
  • 75,988 POSTS
Sounds more like the problem is coming from the turn/hazard switch
Dec 25, 2009 at 9:32 PM
