How DO I get the pumpkin to come off.
I've got all of the Bolts off, even the center bolt on the Pinion. I can't get the Housing on the diff to slide off.
Its also an Sr5 model if that helps any.
I need to replacer the outer drivers side axle bearing.
right behind the the brake drum.
Mar 20, 2008 at 6:07 AM
