1983 Toyota Corolla Sump plug
999,999 MILES • 4 CYL • 2WD • MANUAL
RANDOMFUN
Hey, I have an oil leak coming from my sump plug, now I thought It could be the seal, So I went to go buy a copper washer and put it on...But Its still leaking and I tightened it up well.. Please I need your help, oil is expensive just to waste, plus its a lot of oil that is leaking, mainly when the engine is hot...
Jun 10, 2009 at 7:46 PM
  • 31,937 POSTS
Hi there,
Toyota use a soft fiber seal, i would be using one of there, also check for any old seal left on the sump and if it still leaks you may have a cracked sump.
mark (mhpautos)
Jun 10, 2009 at 10:46 PM
