1982 Toyota Corolla starter
170,000 MILES • 4 CYL • 2WD • AUTOMATIC
AL STONE
have repalced the starter several times believe it was getting hot from the exhoust, so I make sure the timeing was spot on and my last replacement lasted longer. How ever I am in need of replaceing it again. Should I put a heat shield over the starter or is there something else I should do. I am sure that the starter is going bad because of heat. Thanks Al
Mar 2, 2008 at 1:55 PM
  • 31,937 POSTS
Hi there,
These starters do not normally get affected by engine /Exhaust heat. i would be checking the power supply and engine earths first, dont use second hand starters have it o/hauled by an auto electrician and you should not have any problems.
Mark (mhpautos)
Mar 2, 2008 at 6:52 PM
