1982 Toyota Corolla starter
AL STONE
  • 1982 TOYOTA COROLLA
  • 4 CYL
  • 170,000 MILES
Have repalced the starter several times believe it was getting hot from the exhoust, so I make sure the timeing was spot on and my last replacement lasted longer. How ever I am in need of replaceing it again. Should I put a heat shield over the starter or is there something else I should do. I am sure that the starter is going bad because of heat. Thanks Al
Sunday, March 2nd, 2008 AT 9:55 PM
  • 31,937 POSTS
Hi there,
These starters do not normally get affected by engine /Exhaust heat. I would be checking the power supply and engine earths first, dont use second hand starters have it o/hauled by an auto electrician and you should not have any problems.
Mark (mhpautos)
Monday, March 3rd, 2008 AT 2:52 AM
