1981 Toyota Corolla Brake hard pedal
MT08
Brakes problem
1981 Toyota Corolla 4 cyl Two Wheel Drive Manual
Brake hard pedal only starts after traveling about 5 kilometers from home,there is slight braking even not pushing the brake pedal. I replaced the brake master booster but unfortunately nothing changed on braking problem.
May 21, 2008 at 5:07 PM
  • 31,937 POSTS
Hi there,
i would be checking the vacuum supply & check valve for the booster. A hard pedal is a sure sign of a problem booster.
Mark (mhpautos)
May 21, 2008 at 6:06 PM
KHLOW2008
  • 41,812 POSTS
You mentioned slight self braking after some travel, so there might not be enough pedal free play or the booster is out of calibration with the master pump.
May 27, 2008 at 5:58 AM
