1980 Toyota Corolla
GOODJAM
1980 Toyota Corolla
Are the vacuum check valves for a 1980 Toyota Corolla specialized parts or can generic vacuum check valves be used to replace the original? Thank you for your help.
May 8, 2009 at 7:56 AM
  • 75,988 POSTS
Best get the OEM check valves-the orifices on it are calibrated just like the PCV valves wrong type could cause a problem.
May 8, 2009 at 3:57 PM
