1979 Toyota Corolla Won't charge
126,000 MILES • 4 CYL • 2WD • AUTOMATIC
DAVID.53
1979 Toyota Corolla 4 Cyl 1.6 L.. New alternator, new external regulator. Battery fully charged, post clean, new termials. Connector that plugs into alternator clean & fits tight. But battery doesn't charge. I could use some advice. Thank you all for your time & help.
Apr 27, 2008 at 8:47 AM
  • 31,937 POSTS
Hi there,
You will have to re check for any charge rate, if the alt is working, (don't just presume because it is a new unit) Check battery terminals, and have battery load tested. also check for any charging system fuses or fusible links.
Mark (mhpautos)
Apr 27, 2008 at 10:20 AM
