10 amp Gauge Fuse
DECRYPTR
95 Toyota Corolla, 1.8 (7AFE) engine, 173k miles, automatic transmission w/ overdrive.
The gauge fuse powers: temp, speedometer, blower,
rear defrost, and transmission shifting (auto w/od).
When the transmission is put into reverse, the 10
amp (Gauge fuse) blows. Blower at (3), and rear
defrost is off.
Fluid level in transmission is up to at idle, in
park.
(Could this be a shifting sensor)?
Thanks for your time
Nov 28, 2007 at 2:57 AM
FISHERMAN
  • 937 POSTS
[quote:8796be6a5e="decryptr"]95 Toyota Corolla, 1.8 (7AFE) engine, 173k miles, automatic transmission w/ overdrive.
defrost is off.
park.
Thanks for your time[/quote:8796be6a5e]
Disconnect One by one the devices on the list and see which one its causing the fuse to blown..
could be the blower or the reverse switch ..
Good Luck!
Nov 28, 2007 at 3:38 AM
