Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Corolla
Drivetrain
Wheel Stud
Replace/Remove
Wheel studs question
TOYOTA COROLLA
QUESTION?
MEMBER
1 POST
i have a 93 toyota corolla, i was replacing the tire and 3 of the wheel studs broke. How do i replace the wheel studs?
Nov 14, 2007 at 5:10 AM
Experienced Mechanic
You need to watch this video, it help help you change the wheel stud out. It is a different car but the procedure is the same.
https://youtu.be/LSZ8P0wrQX8?si=vY7fXiah0M_Dn2Rw
Let us know if you need anything else.
Nov 14, 2007 at 6:52 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
