TOTOYA CELLICA GT I NEED HEAT
TOYOTA CELICA
PEK
1986 TOYOTA CELICA GT 1800000 4 CYL THE HEAT SOMETIMES WORKS MOST TIME NOT ALREAY CHANGED THERMOSTAT AND FILLED WITH FLUID ANTIFREEZE :?:
Nov 27, 2007 at 7:06 AM
MERLIN2021
  • 17,250 POSTS
Try warming the Vehicle, then carefully feel the heater hoses, are they both hot? If one is cooler than the other, You need to flush the core, or a replacement job on the heater core. Also if the system has a heat control valve on the heater hose, make sure it is working!
Nov 27, 2007 at 7:11 AM
