Heat not reaching car interior.
JWAYSMITH
2001 Toyota Celica GT 96000 miles. The temperature guage shows the engine is heating properly, a/c works fine, fans work, fuses fine, but no heat reaching car interior. The heater hose is warm up to the firewall, inside the firewall it's not. Relay problem? clogged hose? Any ideas are appreciated...it's COLD outside.
Nov 19, 2006 at 8:50 AM
BACKYARDMECHANIC
  • 337 POSTS
There should be a value in line with the heater core. When this value opens it allows heated coolant to flow through the heater core giving you heat.. It is either actived electrically or by vacuum and sometimes mechanically when the heater is turned on. If the value is worrking properly then the heater hose or core is clogged. You can flush them using a garden hose untill you get a good flow through it.
Hope this helps. BYM :o
Nov 20, 2006 at 6:24 AM
