Check engine light
GIOVANNI
  • TOYOTA CELICA
I have a 2002 gt celica, at high rpm the check engine light came on while on 4th gear, when I shifted to 5th gear, the check engine light lit off. It only did this once. Any suggestions as to what it might be?
Saturday, March 4th, 2006 AT 11:25 PM
KGOPEL
  • 13 POSTS
Try to change the Oxygen Sensor. Could be the problem depending on the mileage.
Sunday, March 12th, 2006 AT 1:24 PM
ERWIN_LEON2000
  • 5 POSTS
I dont think there much you can do if it when off couse it could be to many things oxigyn sensor if just one of many things it it the most common but there alot of things it could be you should take it to auto zone they run a free engine check anasis but if it when away you should check it the bulb blew and you acually got an engine check proble take it to autozone the the analisis and theyl give you a trouble code if you got one that means you bulb blew it happens if not your good
Saturday, March 25th, 2006 AT 12:23 PM
