Car wont start just a ticking noise
MAR_PHI6
I drive a 91 toyota celica st 1.6L 4afe motor . After installing a new steering column it doesnt start. when i put the key in the ignition it supposively beep when u insert the key but it beeps once . the headlight work but when u try to crank the or start the car the dashboard doesnt light up nor does the radio or clock doesnt work. i bought a new battery it didnt fix the problem so we tried tapping the starter while starting the car but nothing happpen. Let me know any suggestion or how to diagnose an electrical problem or maybe the alternator is bad
Mar 4, 2007 at 2:48 PM
  • 75,988 POSTS
Double check your work in the steering column, battery connections,check all the Mini fuses, starter relay,clutch switch/NSS and especially the ignition switch.
What make you go in the steering column
Mar 5, 2007 at 6:54 AM
  • 75,988 POSTS
[quote:c4e86b6387="mar_phi6"]I drive a 91 toyota celica st 1.6L 4afe motor . After installing a new steering column it doesnt start. when i put the key in the ignition it supposively beep when u insert the key but it beeps once . the headlight work but when u try to crank the or start the car the dashboard doesnt light up nor does the radio or clock doesnt work. i bought a new battery it didnt fix the problem so we tried tapping the starter while starting the car but nothing happpen. Let me know any suggestion or how to diagnose an electrical problem or maybe the alternator is bad[/quote:c4e86b6387]
Recheck the ignition switch wire harness
Mar 6, 2007 at 5:06 AM
