Car Stall when put on Drive
EMAD MAKRAM
Toyota Celica 1989, ST162, 170K
Greetings to all,
I have a Toyota Celica ST162, that is fitted with 1991/ 1992 imported Japanese Engine, twin cam 16 valve
The car was working perfectly and suddenly stalled and it was hard to start again, after few attempts it started but every time I shift the gear to drive the RPM drops severely and the engine cuts off. Please note that when I shift the gear to reverse the RPM drops a little and the engine keeps running. Could you please advise of what could be dun.
I appreciate you fast response
May 27, 2007 at 2:02 PM
  • 75,988 POSTS
[quote:59a3536f9f="emad makram"]Toyota Celica 1989, ST162, 170K
Greetings to all,
I appreciate you fast response[/quote:59a3536f9f]
Check the igntion timing,idle air control valve,throttle position and mass airflow sensor.
May 27, 2007 at 3:34 PM
EMAD MAKRAM
would The changing of fuel pump and transmission services would help especially that the car does not stall when I put it on reverse [quote:11316ca849="rasmataz"][quote:11316ca849="emad makram"]Toyota Celica 1989, ST162, 170K
Greetings to all,
I appreciate you fast response[/quote:11316ca849]
Check the igntion timing,idle air control valve,throttle position and mass airflow sensor.[/quote:11316ca849]
May 27, 2007 at 4:07 PM
  • 75,988 POSTS
When was it last major tune-up? When it dies out immediately check for spark-spark okay-check the fuel pressure. Get these areas check out before you deal with the transmission.
May 27, 2007 at 4:28 PM
EMAD MAKRAM
Is the idle air control located on top of the air filter cover and could you please describe the mass airflow sensor and where it is located, many thanks for your prompt response and excuse my ignorance being an imported engine. [quote:b35256c0d5="rasmataz"]When was it last major tune-up? When it dies out immediately check for spark-spark okay-check the fuel pressure. Get these areas check out before you deal with the transmission.[/quote:b35256c0d5]
May 27, 2007 at 4:37 PM
  • 75,988 POSTS
[quote:6ad0d564c0="emad makram"]Is the idle air control located on top of the air filter cover and could you please describe the mass airflow sensor and where it is located, many thanks for your prompt response and excuse my ignorance being an imported engine. [quote:6ad0d564c0="rasmataz"]When was it last major tune-up? When it dies out immediately check for spark-spark okay-check the fuel pressure. Get these areas check out before you deal with the transmission.[/quote:6ad0d564c0][/quote:6ad0d564c0]
The IACV is within the throttle body and the MAF sensor is in the airfilter box.
May 27, 2007 at 7:01 PM
